Replace Microstep Driver M542-05
funhawke
My Z driver pouched - can I replace a "Leadshine" Microstep Driver M542-05 with a ECNC-2M542? Looks like this is the replacement but wanted to verify
Re: Replace Microstep Driver M542-05
As long as both drivers having the same type (2phrase or 3 phase) and similar micro stepping/current range, sure you can make swap it without an issue In your case, I'm pretty sure you can do direct replacement.
