1 Ch RF Controller 1527 Power Issue
cerca
Post by cerca »
Can anyone please let me know if they have tried this and if so what value of the Capacitor I would need. I am using the 1 channel 1527 and on startup the voltage drops below 10 volts and to 9.87 volts and makes the module not function properly. I was thinking of putting a cap across the the power input to act as an extra power source on startup to stabilize the voltage for 300 MS or so. Does anyone have any ideas if this will work and if so what the value of the Capacitor should be. Thank you in advance. Chris
Re: 1 Ch RF Controller 1527 Power Issue
Capacitor wont hold voltage for such long period. It act as a 'fitler' It is your battery issue
