Reci Tube InstalL(SOLVED)
funhawke
Installing new Reci tube. Previous tube soldered reci tube indicates NO SOLDER. Attach to screws on each end with a spade connector OK?
Re: Reci Tube Install
It is not just the RECI tube alone, it is for all laser tube that you can NOT use soldering iron to make connection, otherwise you may break the seal and causing air leaking. RECI has a screw on each end where you connect the High voltage and ground wire to it.
funhawke
Great. The one I removed seems to be soldered but perhaps not. I will use a electrical spade connector and attach to screws at each end. thanks
funhawke
Re: Reci Tube InstalL
OK Tube installed fired up works. Is there a chart suggesting amp readings on various settings?
