Stepper Motor Issue
paudie2010
Stepper Motor Issue
Hi All,
My 1st post here. I have upgraded to the AWC608 upgrade kit. Since upgrading the stepper motors in the XY have been moving very slow and not stepping properly. The motors work fine when using the manual controls but when I send any job from LaserCAD it doesn't work. A simple text engrave is estimated to take 20 minutes which I also find strange. I have double checked the settings on the stepper drivers and they are correct with the documentation I got for the upgrade. Any help is greatly appreciated
Re: Stepper Motor Issue
Please post the manufacture parameters and the User parameters setting here. I May be able to help you to solve the issue
paudie2010
I can't open the link somehow. What I need is the manufacture and User parameters setting from the LaserCad, not from the LCD panel. Please use screen catcher and post it here. Image size is limited to 1500dpi
Thx
Thx
paudie2010
Sorry you couldn't open files. I will attach them here in 2 posts. Here are the manufacture paramters
- man_parameters.PNG (43.88 KiB) Viewed 6949 times
paudie2010
User parameters:
- user_parameters.PNG (35.76 KiB) Viewed 6948 times
What micro stepping are you using on the motor drivers?
Can you post some pictures on your machine?
It seems that the Y has 2:1 reduction gear but Not on X, right?
Is it linear guide or Y wheel system?
You may want to lower the Space_Jerk and Cut_Jert to 25,000 and 20,000 respectively.
tansh
Maybe the um for x/y are not set properly in the manufacturer parameters?
You tell me
See the "FAQ" where I showed how to do 'um' calculation. Let me know if you have any question.
paudie2010
Here are a few pics of the machine. The stepper drivers and the sheet I got from LightObject to follow for setup
Those pictures don't tell much.
No stepping info, No current setting, and no motor information.
You need to show us the driver setting and the specification of the motor.
paudie2010
The stepping info I was supplied with the kit is in the pics. 0.63A, 16 Microsteps? I can't find the data sheets for the motors....
The stepping of 16 seems ok. But you got to find out the current rating. Without proper current it could be under current causing escaping or overheat when over current. Well, you may need to do "test and try". How big of your machine?
