Cornering speed problem
Agent Sevan
Post by Agent Sevan »
Attached is an example photo of what should be a square. As you can see it outruns one of the axes. That was cut at 25mm/sec. I've tried adjusting the space and cut jerk and turned down the speed factor and cut acceleration but i get the same results whether I'm cutting at 25mm/sec or 60mm/sec and no difference comes from adjusting the settings I mentioned.
Belts are also on tight
Any advice?
Re: Cornering speed problem
Before I can make suggestion:
Post your machine information
Post DSP User Parameters
Post DSP Manufacturer Parameters
Agent Sevan
Awc608 controller. Leadshine MD882 stepper drivers, Leadshine 57hs22 stepper motors. The laser is a Universal 60 watt water cooled tube RF laser.
I've had a very curious issue with the user parameters where I will read then save new settings.... then when I go to read again it shows the previous settings and not what I saved.
The attached photos are
1. Manufacturer parameters.
2. User Parameters as I have saved them
3. User parameters as they appear after I press "Read"
This is with the controller turned on and connected to my computer.
I think your machine is "undershoot" because acceleration were set too slow on User Parameters.
If your machine isn't a bulky machine like those tube ride on type, you should never set Cut_acc or Space_acc under 2000
Plus, the Cut_Jerk and Space_Jerk should set to 50,00p and 30,000 or bigger number unless you have a very big machine. Even our 2500x1400, I set 18,000 and 15,000 respectively
Agent Sevan
My Y axis does move some weight around... 1200mm x 1200mm table with metal honeycombs.
So what do settings do you recommend I try next?
Agent Sevan
With the settings that you use for your large table (18,000, 15,000, 2,000 and 2,000 this is my result. Same thing.
If I use the default faster or fastest params the stepper motors just bind and grind.
