Cutting Sequenze does not work
typomaniac
Post by typomaniac »
Hello,
i use lasercad 7.78 together with the lo-x7. I have problems with the sequence (order of cutting / engraving): I made 4 layers
with
Layer 1 cut, 4 speed, 40 power
Layer 2 cut, 30 speed, 10 power
layer 3 engrave, 150 speed, 12 power
Layer 4 2 cut, 5 speed, 40 power
Layer 4 should be the final could of the object (Acrylic). What the laser does is:
Engraving (layer 3), Layer 2 (only parts), Layer 1, Layer 4 (cutout) and .. then the rest of layer 2 (which does not work because
it fell down in my laser when being cutout). I tried using the »manual order« function in lasercad but without success. Do i understand
something wrong?
thanks!
tm
Re: Cutting Sequenze does not work
TM
There is a setting where you can enable the sequence. I am not on my computer so I can't show it to you. When I get back to my room (I am in Seattle now), I will try to make a screen shot for you
See attached image
typomaniac
thank you!!! That worked ...
I got no notification so sorry for the late answer!
