This is a complete kit of PRO530 XY stage with E5 DSP. It is built with 20mm extrusion aluminum. The stage is ready to sell and the extrusion aluminum is available sometimes on July. So, before you're planing to buy similar machine from 'eBay' and then spent $1000 for the upgrade, you may want to consider this one or the turn-key machine!
The machine comes with Element E5 DSP controller card, 500x300 honeycomb, high quality LO 850mm 40W laser tube, PR530 high speed XY stage, 40W laser power supply, DC24V 10A power supply, 30mA analog current meter. Power Z table is included
Optional parts: LO600W water chiller, beam combiner
The max engraving speed is 1500mm/s (max). The optimal speed is 1000mm/s (less time)
Overall size: 940mm x 620mm x 280mm (37" x 24.5" x 11")
New Pro XY stage (500x300) Kit and Turn key machine
Re: New Pro XY stage (500x300) Kit
Turn-Key machine update
- IMG-20160429-WA0008.jpg (25.95 KiB) Viewed 29209 times
- IMG-20160429-WA0007.jpg (45.51 KiB) Viewed 29209 times
- IMG-20160429-WA0006.jpg (37.47 KiB) Viewed 29209 times
- IMG-20160429-WA0005.jpg (42.92 KiB) Viewed 29209 times
- IMG-20160429-WA0009.jpg (36.78 KiB) Viewed 29209 times
Prototype machine
