Illustrator plugin error with Lasercad
DWayne
Illustrator plugin is not working for Lasercad using X7 dsp. I'm running 32bit CS5 Illustrator in Windows 10. I'm getting a popup error when Illustrator starts that reads "Error loading plugins. AWCPluginEn.aip.". A search on my computer does not find an AWCPluginEn.aip. Lasercad runs fine on it's own. Any advice on fixing the plugin error would be appreciated.
Re: Illustrator plugin error with Lasercad
I already talked to the programmer and he said that he would spend some time on the Plugin for the Illustrator
natemart2
Is there any follow-up on this? I am running into the same problem.
cryoteck
I'm chiming in of this as well, would love to get a Plugin for Illustrator!
