New shipment arrived.
I have received a batch of great tube for the K40 (720mm), 850mm, and 1M tube. Will let them to brand name it to "LightObject" in the future. The beam quality seems the best so far I have so many different brand. That's why I'm going to let them oem it for us.
Also, I have tried a few power tube from a new manufacturer and the result was amazing! For a 100W and 130W tube, the beam diameter at 1ft away was about 6mm and 8ft away the beam diameter was 6.85mm. Such a good beam quality was totally unexpected even though Reci tube can't do better. Plus, there is ceramic blocker attached to the tube so that the hot wire is inserted inside of the ceramic blocker to avoid arcing from happening. That is the first time I found such a good design on a tube! I will post some pictures later
