Laser not switching off between cuts
Agent Sevan
Post by Agent Sevan »
Attached is a screen shot of the simulation. Two squares, 4 circles. The problem is the laser doesn't shut off between objects so my cuts look just like the simulation.
Any advice?
AWC608 controller. Universal 60watt co2 laser
Re: Laser not switching off between cuts
Check the "TL" or "TH" connection between the DSP card and the power supply. You may have wrong connection
Agent Sevan
Turns out the problem was I had my settings set to glass tube. When I switched it to RF everything fired fine.
