laser head parts ..sizes?
TSHobbies
Post by TSHobbies »
Im looking to get some parts for our laser head.. Im needing the 38.1mm adapter, but dont know if it'll fit our machine,or what size lenses this part holds..
http://www.lightobject.com/381mm-focus- ... -P953.aspx
Our lenses are 20mm . The diameter of our lense barrel at the threaded opening is 21mm
This item looks to be the exact same assembly we have on our machine...so,will your 38.1 adapter fit on ours?
http://www.ebay.com/itm/Co2-Laser-Head- ... C4kpCa-xng
Re: laser head parts ..sizes?
Sorry can't really tell whether it fit or not. It is not just the size of the laser tip or the barrel but the threaded size must fit in order to work. FYI, it is non-standard and there are thousands of manufacturers in China who make similar parts.
