Hey,
i want to upgrade my diy laser which is running with the lo x7 dsp. I bought a LJ8A3-2-Z/BX inductive proximity sensor for using autofocus on my machine.
The sensor has three wires. I know how to wire this to an arduino (6V, GND, Signal) but i do not how how i can use it with the dsp as a switch for the z axis
and therefore for autofocus. How can i wire and use this to the unit?
thanks a lot,
tm
How can i wire induc. proximity sensor to x7 for auto focus?
typomaniac
Re: How can i wire induc. proximity sensor to x7 for auto fo
The same... Brown to +V (24V), Blue to GND and Black to signal in (ELZ+)
typomaniac
thank you! Do it put gnd to the switches ground an the x7 or to the power supplys gnd?
thanks again!
tm
thanks again!
tm
You can connect all wires to the controller..
Greolt
I use a three wire sensors (hall effect) for limit on X and Y.
Connect to appropriate connector, 24v, GND, and correct input pin.
typomaniac
awesome. Thank you, both!
