Having problems with X7 controller not saving the settings for water protect or hardware limits.
I am using PW 608 on the controller.
Anyone else seeing this problem?
X7 controller not saving WP or hardware limit
spk64
Re: X7 controller not saving WP or hardware limit
Correct.. This is a known "bug" in the combination X7 and LaserCad.. (apparently still not solved)
Just neglect the settings in LaserCad and set them in the X7 directly:
Press Stop an Shift to enter the manufacturer setting and alter the WP settings there..
Actually it isn't a bug. The programmer intended to do that way out of some reason. I already discussed with him and he will try to add it back to the LaserCad. It may 5ake a while because he is working on a new baby DSP controller for me.
spk64
I found lots of good info here. Also had the stop shift combo.
viewtopic.php?f=8&t=2783&p=13378&hilit=Password#p13378
All is working great now!
