Everything was running smoothly until recently. I have the x7 dsp on a k40. It works fine after the first engrave, but once the power is turend off, the lens is trying to move to the home position all the way to top right/far right on the X Y axis (off the cutting space). I have to manually stop it before it goes too far. I have tried everything I can think of in the settings to get it to start at the proper spot , but nothing is working, any suggestions on settings I need to change to fix this. I am unclear what I changed to cause this.
Thanks!
can't reset home for x7
lasertime
Re: can't reset home for x7
Either a bad home switch or losing cables connection that attached to the Limit Switch terminals of the DSP controller.
