Lo-1600w alarm outputs
spk64
Post by spk64 »
Does anyone have a schematic of the alarm outputs for this chiller?
spk64
Re: Lo-1600w alarm outputs
Post by spk64 »
Could it be the same as the cw-5000 units?
Possible.....
You can download the CW-5000-manual everywhere.. compare the connections and their functions..
Will post a picture to show the normally open contact soon
shanet94
Post by shanet94 »
Tech_Marco wrote:Will post a picture to show the normally open contact soon
Great i will be wiring this in soon myself ;)
Done!
Connect 1 & 3 to the "WP" and "Gnd" on a laser power supply to serve as a 'safe gate'. When water is flowing, the 1 & 3 became closed contact to enable the laser power supply. If water is not flowing, the 1 & 3 is opened so that it will disable the laser power supply
P.S. Would everyone who has purchased the LO water chiller leave a review on it. Both Pro and Cons are welcomed. I'll discuss with the manufacturer for future improvement. Thanks!
shanet94
Post by shanet94 »
Tech_Marco wrote:Done!
What if you already have a flow switch hooked up to those? Just add these with it?
Regards
Shane
Then you don't need it. Or, you connect it to the DSP controller for another layer of protection. Or, you can put it in series connection with the water sensor you have hust in case a water sensor gone bad
shanet94
Post by shanet94 »
Tech_Marco wrote:Then you don't need it. Or, you connect it to the DSP controller for another layer of protection. Or, you can put it in series connection with the water sensor you have hust in case a water sensor gone bad
If we hook it to the DSP hook it to wp/ground on laser1 (#6)
spk64
Post by spk64 »
Thank you Marco.
Only been running it a short amount of time but seems good. May also run it on my CNC water cooled spindle.
I was thinking of running the water protect circuit in series with my other switch. Would rather have extra protection than not enough.
