For AWC608:
Note: before running the OS patch, make sure that you have erased all files stored in the DSP card or the DSP will not perform properly.
After OS is applied, proceed the following:
For X7, press "Stop" & "Shift" key on the LCD unit to enter the parameter menu where you need to set the mini power % for the RF tube to the lowest. Make sure 'RF tube' is selected. Default is CO2 glass tube.
For both X7 & AWC608, select "No-preignition" on LaserCad parameter setup.
After save the change, make sure to press "RESET" to initiate the DSP for the new setting.
Regards,
Update AWC608 (last update)
Return to “DSP Laser Controller”
Jump to
- Special note
- Administrative Category
- ↳ New Product on the board
- ↳ Latest News
- Sell & Wanted
- ↳ Laser products
- ↳ CNC products
- ↳ Electronics products
- ↳ Others
- ↳ Repair & Upgrade
- ↳ Product Lab
- ↳ Cutting & Engraving tips
- ↳ FAQ (laser)
- ↳ AWC7824
- ↳ AWC7813
- ↳ Ruida R6445G/X
- ↳ DSP T9
- ↳ DSP X7
- ↳ DSP R5
- ↳ DSP E5
- ↳ DSP 608
- ↳ CO2 Laser Discussion
- ↳ News
- ↳ Auto focus laser head
- ↳ Introduction
- ↳ CNC zone
- ↳ Temperature Controller
- ↳ Electronics
- ↳ RF Wireless Controller
- ↳ Digital/ Analog Meter
- ↳ Laser & CNC products
- ↳ DSP controller
- ↳ Water Chiller
- ↳ Laser power supply
- ↳ XY gantry and frame
- ↳ Motor driver
- ↳ K40 small laser
- ↳ LCD Module
- ↳ AC Power Frequency Meter
- ↳ Other electronics devices
- ↳ Water pump
- ↳ LED
- Software Download
- ↳ DSP Laser Controller
- ↳ Fiber Laser
- ↳ Flying
- ↳ Others
