Hello, I have a mach 3 home built laser system running gecko servo drives and servo motors. Is your dsp laser controller compatible with servo motors?
thanks
Scott
dsp laser controller and servo motors
creativecorp
Re: dsp laser controller and servo motors
Yes, it does. Go to the manual section and down the manual.
creativecorp
Thanks Marco.
I have read through the manual. I think the manual makes mention that the motion controller board "could" be used to control 2 motors per axis. I have a gantry that uses two motors for the x axis, each driving its own ball screw, one is set as a slave. The y axis only uses one motor. Do you know if this can be done with the motion controller board?
Scott
Scott
I was told that the support can support two X driver and one Y
