Password CorelDraw macros
SmoothY
Post by SmoothY »
HellO !
Someone he knows the password of macros for coreldraw and AutoCad ! I would like to translate into French for simplicity ! :D
Thank you very much ! ;)
Re: Password CorelDraw macros
Post by baccus61 »
Not sure which password you need but here are the ones Marco posted a while ago
811104 (Master key code to release demo time)
gxfc88 (Write machine info to configuration file)
dimky
Post by dimky »
I would like to translate corel draw plugin too. My native is Russian. :)
moto202
Post by moto202 »
For translation the password for VB-Editor to open the macro is needed.
The Passwords stated above don´t work...posting.php?mode=reply&f=8&t=279#
SmoothY
Post by SmoothY »
Hello !
The code does not work gxfc88. I tried to crack the code with a hex editor :ugeek: I get to have a small part of the source code only and not re-register .. :cry:
Nobody knows the code that works ? :|
lanoph
Post by lanoph »
Hello,
I changed the Password for the GSM-File. It is now "start". replace the GSM-File with the attached
RLaser.zip
(21.28 KiB) Downloaded 300 times
and try.
I tryed also to translate the Shield.
But it is not in the Plug-In for Corel. The Plugin only export the data to the RLaser.exe. I thin you should try to open theis file and translate it there.
If someone finds a way.
Please let me know.
SmoothY
Post by SmoothY »
Hello!
I come with good news! Looking in the hexadecimal code of the executable TZsetup.exe I realized that all the text were gathered in one place in the form: 1 = Open Trans Err £ º ¡£ 2 = failure Trans Com Err error £ º £ ¡. ...
And just before this paragraph is something I entangled "eng.txt.dll" I made a
search on my pc a file eng.txt and I found it ! in:
CorelDRAW Graphics Suite X4/Programs/eng.txt
Just translate it !!!!
Excuse me for my English very poor .. And good translation !
