You may want to use the attached file to your machine see if any mechanical issue.
If you see double line from the return path, that mean your machine Fail the exam
If you have double line, chance is that even with 20mm/s, it will still appear. We shouldn't see double line even with 500mm/s
I'll post more complicate file that anyone can download it for testing.
Alignment test for your machine
- Wheel_Single_RD.ai
- (55.16 KiB) Downloaded 251 times
