Y homing not work!
nue
Y homing not work!
Post by nue »
awc708lite :( i have problem turn on power X axis homing ok! but Y axis homing no respond .And i duoble checked everything in parameter.help me please
yaddatrance
Re: Y homing not work!
Post by yaddatrance »
Check the pins on the cable between the screen and the breakout box, I had a similar issue and one wire was broken at one of the ends so I resoldered it and it worked.
nue
Post by nue »
Hi !! yaddatranc :D thank you so much,effective experiment is how , already will come to a report ,
What setting on the motor driver? Micro-stepping and current setting?
Also, what kind of machine are you running with the DSP? Did you set up "um" for the motors?
If it is for the K40 small machine with direct driven, try use um at "6.5" or "12.5" and it should pick up some speed. then do the fine tube. See my FAQ pages.
