Hi.
Then i want to write parameters to the PH-board from Rlasercut it ask for password. I have tried with the six digit number included in install package but i will not work. Any suggestions?
Best regards, Klas Pettersson - Sweden.
Code to write parameters.
dekaltrim
Re: Code to write parameters.
811104 (Master key code to release demo time)
9xfc88 (Write)
9xfc88 (Write)
dekaltrim
It gives password error. I change something on X-axis and push write. Then i type 9xfc88. And i get password error back as answer. My card is PH/Board v1.2 and i download rlasercut from your pages yesterday.
And the code button under settings is grey and not possible to use.
maralb
How about "634590"
dekaltrim
It was wrong code. It should be gxfc88 instead of 9xfc88. so it solved now with a little bit help.
Thanks.
Thanks.
Ding~~~ how could I miss that! Yes, it's 'g' not '9'
Thank you
Thank you
