power on will not stop
Oneleggednews
When I power on my laser goes to top left corner and will not stop unless I push the stop button once I get it stopped it work fine have limiter switch on both X & Y to no avail. I start all the jobs I have tried from center of table.
MrMag
Re: power on will not stop
Sounds like the micro switch may not be working. try to start it again and manually push the switch. Watch your hands. If it stops, it may just be out of adjustment. I hope this helps.
Oneleggednews
