z table will not move
Oneleggednews
I got my engraver to engrave but still can not get z table to move ether with panel or software how can I power it manually with direct power
NickWL
Re: z table will not move
The solution depends on whether it is not moving for (a) electronic/control or (b) mechanical reasons.
If (a) then wait for someone else to reply.
If (b) then, assuming the motor is grunting, slacken off the four screws holding the top frame down and see if this helps. It did for me.
Oneleggednews
I took it out and tried to run dead no ohms between wires
