High performance 5 axis Break-out board for CNC driver.
This is a a break-out board support up to 5 axis motor driver. It's built in relay and limit sensor inputs. Each channel comes dual output port: phoenix termianls and Cat-5. Unlike others, it used high speed optical coupling to interface motor driver. Therefore, higher responding speed achieved and provide better peformance for your CNC system. It's much better than other board that comes wihtout or using low speed coupling.
