Just drawing a single line after upgrade
Jason
Post by Jason »
Hi all,
I have just finished the 608 upgrade to a K40 and have followed the instructions to cut the box on a piece of paper and then measure it. I have done this and entered the UM values completed the reset.
I redrew the box to check the result downloaded it and now it comes up with beyond size, continue? when you accept this it only cuts a line along the Y axis then stops and returns to home. Any Ideas?
Regards Jason
NickWL
Re: Just drawing a single line after upgrade
Post by NickWL »
Best guess would be that you got a decimal point wrong entering the new numbers. Certainly worth re-entering as a try.
Nick 8-)
Jason
Post by Jason »
No values look good I have even tried resetting UM to 5.0 and testing the square again and just a single line.
Reinstalled LaserCad and still the same thing?
Any Ideas?
Check the "User Parameters" where you will see the Page Zero and Machine zero. Make sure it match your Home location.
Also, on the menu bar, there is a button name "Position Relative" make sure it match the Home location as well
After those parameters fixed, you should be able to cut the square box. But, before doing so, make sure you zoom out the image as the original drawing for sure will be out of the boundary. Ether center it or redraw it. Then, the last step is to hit "RESET" button on the LCD panel to take the new setting in effect
Jason
Post by Jason »
Thanks Marco
It fixed the problem.
Regards Jason
