laser cookies
brian257
laser cookies
Post by brian257 »
I can confirm that yes, Virginia, you can engrave and cut Christmas cookies on a CO2 laser. At least sugar cookies anyway. Wife has not made any Gingerbread to try yet.
While the cookies can be cut, the cut areas do taste burnt and pretty bad. Engraving, however, works good and does not change the taste noticeably as long as you don't try a deep engrave.
And why would anyone try this? Well, my wife does an incredible job hand decorating the cookies by hand with each of them different. I wanted to put her name and "Christmas 2014" on the backs for an added touch.
When I first got the laser I cut "I love you" in a slice of toast and it made the expense of the laser go down a little easier.
prcdslnc13
Re: laser cookies
Post by prcdslnc13 »
Pics or it didnt happen :P
swamidog
Re: laser cookies
Post by swamidog »
i've had good luck with tortillas ;)
prcdslnc13
Re: laser cookies
you sir, made my day :ugeek:
brian257
Re: laser cookies
Post by brian257 »
Love the tortillas! I will definitely have to try that. Thinking some special breakfast burritos in bed for my wife on Valentines. Might help with telling her that I need to spend more money on building a bigger laser.
I told my wife that if she polishes her nails I can selectively burn through the polish and give her some pictures etched in her nails. So far she has not let me try it. I don't understand. What could possibly go wrong as I experiment with different power and speed settings?
swamidog
Re: laser cookies
Post by swamidog »
there's actually quite a lot of information about laser etching fingernails online..
i'm not sure that would make your wife more comfortable. ;)
http://www.instructables.com/id/Thumbna ... e-between/
brian257 wrote:Love the tortillas! I will definitely have to try that. Thinking some special breakfast burritos in bed for my wife on Valentines. Might help with telling her that I need to spend more money on building a bigger laser.
Maverick
Re: laser cookies
Post by Maverick »
It also doubles as a cuticle remover. Now all you need is a CNC router and a buffing pad and you've got a robotic manicure. If you're really brave, swap out the buffing pad for a diamond tip and make that mustache come alive in 3D! :eek:
edit* Back on topic... I'm going to try the cookies later tonight.
