Which end is which?
AndyKunz
Which end is which?
Post by AndyKunz »
This has to be about the stupidest set of questions you'll see here...
1) I have a LO 60W 1200mm tube. How do I know which end is the light output end? I'm assuming it's the end with the metal ring, not the terminated glass-only.
2) Does it matter which end the chilled water comes in?
3) Anybody have a photo of one installed in their machine?
Thanks.
Andy
Re: Which end is which?
:eek:
It is the one with a mirror can be seem from the outside
Or, the opposite side of a glass coil .
Water in general is coming from the coil side the out at the beam output side
AndyKunz
Post by AndyKunz »
Thank you, Marco.
Next question - how are these attached to the machine. I'm sure they just don't lay in the V-block without some sort of top restraint.
Should there be a foam rubber between aluminum V and glass? Or is glass-to-aluminum OK?
Andy
Andy:
Sorry for late reply. What you need to do is to put a piece of soft foam on top of the mount will take car it. Or, a soft rubber can do the trick. You sure don't want to lay down on top of the metal mount without the cushion
AndyKunz
Post by AndyKunz »
Thank you. I have a great product for this.
What kind of retainer is used for the top of the V blocks? Do you sell them?
Andy
I use spring. Hardly it wore out like rubber band!
I have some in stock but never got a chance to post it
AndyKunz
Post by AndyKunz »
Great idea! I can get them from the True Value store where my son works.
Thank you!
Andy
