AWC608 cutting 12% larger on X and Y axis than drawing.
Unlikelygeek
Post by Unlikelygeek »
I've upgraded from leetro 6525 and all looks fine except the final product is 12% larger.
The drawings are dfx's which import perfectly into LaserCad and all dimensions are as drawn in CorelDraw X6.
What setting do I need to change?
Any help is appreciated.
Greolt
Re: AWC608 cutting 12% larger on X and Y axis than drawing.
Post by Greolt »
First thing to look at is the step distance setting
It is found under System Settings / Manufacturer Parameters
Labelled "Um/Pulse" which interprets to, distance the axis moves per one step in micro meters.
Laserbright
Post by Laserbright »
Thanks Greolt, that worked a treat.
