ECNC-2X6560A New version 2 Axis CNC/ Laser Machine Stepping Motor Controller (TB6560). Support Mach3 & KCam
Bought one of these K40-III lasers and the MoshiDRAW board is not working. So I yanked it out. I ordered a Blue Board TB6560's to install. I came across this product ECNC-2X6560A for-sale on here and don't see anyone making a mention of it. I don't have a problem buying this one if it works could always use the blue board as a backup.I run CNC Mills in my shop and have a need for a laser to cut out small parts that a router will devastate sometimes. I use MACH3 and supporting software so I'm sticking with what I know for the moment. So my question is this has anyone or is anyone using this board? Does it come with documentation to set it up inside the K-40 and MACH3. I have alot to do and trying to cypher through all the forums is not what I need to do to get this puppy to work.
Thanks in Advance for any support here
ECNC-2X6560A
zann68
Re: ECNC-2X6560A
Well I guess this board is not available and everyone seems tight lipped about it anyway
. I installed the BLUE Board and all is well except one little problem - Laser stays on in motion to next cut?!? Nothing I do seems to resolve the issue. Being a broke DIY'er this is what I got to work with, cant afford this DSP item. I'm following this setup to the T's "http://www.cnczone.com/forums/general-l ... board.html" Stepper motion is good as the safeties I added. I get a 3.3 v trigger via my "Z" motion pin the laser fires. I still get a 0.100 v on off or "Z up" so the laser is still hot. What to do? Surely I'm not the only poor joker to have this issue?
Pleading for Help!!
Jeff
Pleading for Help!!
Jeff
