Ink Scape with DSP
davem506
Ink Scape with DSP
Will Ink Scape work much like Coreldraw when using the DSP?
Re: Ink Scape with DSP
One user on CNCZone has set up InkScape with MosheDraw and it worked ok but I don't know if it will work with LaserCad. Apparently Moshe is crap but you would have to Ask Marco if it is compatible with LaserCad.
I don't know if it will work as a stand alone program as I have never tried it like that.
swamidog
i had no problems tracing bitmaps with inkscape and exporting as dxf for lasercad, but i was unable to try talking directly to the dsp with it as it was running on a different machine.davem506 wrote:Will Ink Scape work much like Coreldraw when using the DSP?
