Does the Upgr-Kit AWC608-Commercial work with SF 400 Laser?
JHum
Post by JHum »
Hello Supportteam, Hello Marco
I'm working with a China-Laser "SF 400", which is variant of the small mashine, with 350 X 400 mm-workspace. I have a lot of touble because of the manufacturers original build in electronic and even with moshidraw.
Is the following Lightobject-Upgrade-Kit
http://www.lightobject.com/AWC608-Comme ... -P321.aspx
compatible also to this machine, do you already have collected experiences?
I'd be glad for some supporting ideas!
JHum :?:
Re: Does the Upgr-Kit AWC608-Commercial work with SF 400 Las
it should work well and I dont see why not
Regards
