lasercad V.688 is missing PPI setting
Post by waltfl »
Hi all
I just realize after installing that at the lasercad V. 6.88 the selection for PPI is greyed out and can not be used.
why is this???
Radishworks
Re: lasercad V.688 is missing PPI setting
Post by Radishworks »
Does anyone have an answer on this question? PPI is disabled for my 6.88 version too?
What's OS you guy have?
Open a file name "SoftCfg.ini" under the LaserCad\AWCCfg folder with notepad or any text editor.
Change "IfEnbleCountAndPPI=" from "0" to "1"
After change, it should look like this: IfEnbleCountAndPPI=1
That should solve the problem
Radishworks
Tech_Marco wrote:Open a file name "SoftCfg.ini" under the LaserCad\AWCCfg folder with notepad or any text editor.
Change "IfEnbleCuntAndPPI=" from "0" to "1"
Works great, thanks!
BTW I think you meant "IfEnbleCountAndPPI=1"
