I'm posting the DSP LCD control unit front panel layout for K40. Note that the screw hole may not be 100% alignment as the K40 is not 'quite' standard. You may edit yourself by using CorelDraw v12 or above version.
K40 front panel mount for DSP card by CorelDraw V12
- K40panel.JPG (27.64 KiB) Viewed 39900 times
- LaserFrontPanel CDR12.cdr
- Download this file
- (191.01 KiB) Downloaded 1680 times
Re: K40 front panel mount for DSP card by CorelDraw V12
Sorry, the above cut out is designed for SOLO with TB6560 driver card only. It is not for the DSP.
For the DSP (AWC608), please download the file below LaserCad file instead.
- DSP SOLO USB CUTTING 1.pwj5
- (208.93 KiB) Downloaded 1754 times
- DSP SOLO PANEL CUTTING 2.pwj5
- (403.78 KiB) Downloaded 1743 times
- DSP SOLO PANEL CUTTING 3.pwj5
- (63.14 KiB) Downloaded 1663 times
