Now it cuts a test square nicely, but if you rotate it 45 degrees to get both motors turning at the same time it creates a wobbly cut. Also if you do a large sheet it doesn't always meet at the ends. It sometimes shifts out of place but not always in the same spot.
I'm pretty sure its hardware, but I can't tighten the belts any more as they jam. I have a pencil line of the pulley to make sure its not slipping, it doesn't seem to. I have noticed a wobble in the y axis drive shaft when its connected to this.
Not this version, its one that came with the lite stages but I couldn't find a pic of that one.Its quite noticeable but I can't seem to eliminate it no matter how I try to adjust the grub screws. Could this be the cause or has my belt stretched? If so can I get one in the UK? And what to search for if so?
Any ideas would be gratefully received as I'm tearing my hair out.
Tim.
