Wiring diagram needed for NEMA 17 42HS02 Stepper motor
Anthrobones
Post by Anthrobones »
I recently purchased the NEMA 17 42HS02 Stepper motor, and I need the breakout for the wiring. Not depicted on the website, please post.
Re: Wiring diagram needed for NEMA 17 42HS02 Stepper motor
1 & 4
and
3 & 6
If you connect 1 & 4 together (shorted circuit), you will find some resistance when you twist the axial. If you free no difference (freely move), then 1 & 4 is not in pair, so does 3&6. It is the basic testing method to find out the stepping motor pairing
Anthrobones
So your telling me to hook it up, POWER IT, and feel for resistance? You cannot simply tell me the pin-out for a product you sell?? Are you going to replace it when I blow the motors?
Tech_Marco wrote:1 & 4
and
3 & 6
Stephen6309
Post by Stephen6309 »
Spinning a stepper motor by hand won't generate much current to damage the motor. You can also use a multimeter to see which pairs are connected.
Anthrobones wrote:So your telling me to hook it up, POWER IT, and feel for resistance? You cannot simply tell me the pin-out for a product you sell?? Are you going to replace it when I blow the motors?
I already told you that it is 1,4 and 3,6 . I just wanted to tell you more how to test a stepping motor without knowing the cable. If you can't do it, no problem just send it back for refund.
Return to “Others”
