Using the same power and speeds I used to use on the old stages, my 50x50 box is spot on for size, but the cuts go all the way through on the Y lines but not on the X, its nearly there, but not quite. Its not an alignment problem as the Y parallel lines are both cutting evenly, Could it be a stepepr setting? I haven't changed the stepper drivers, as they seemed to work well, I've got the ECNC-2M542 driver,s and the 600x 400 lite stages, does anyone know the setting I should have them on?
thanks in advance,
Tim.
