Software version
mondo50m
Software version
Post by mondo50m »
What version of the software are we on? I am on 6.27 is that the latest?
Milt
Re: Software version
Post by waltfl »
Hi milt
as far as I know it is 6.47 but after 6.37 is just minor OS stuff what is not worth I am waiting for the next
bigger one
mondo50m wrote:What version of the software are we on? I am on 6.27 is that the latest?
Milt
Walt is right. There is not very much have done on the latest version LaserCad even though it is v6.47. It's just a few minor fix for big machine only and there is not much difference vs v6.27.
I'll wait for the 'big' change before I post a new one. Currently the programmer is working on "Print driver" and that is a big change and I want to wait for the completetion before I launch another version
Marco :)
Redgee
Post by Redgee »
i´ve heared, that on Tunderlaser DSP Software is a new material bibliothek.
I think this would be a great thing to the 608 too.
Marco can you tell Mr LEE about it?
thanks.
Greolt
Post by Greolt »
Can Mr Lee include an option to disable Z axis soft limits while he is at it? PLEASE.
Greolt
Mentioned it to him yesterday. So, he may give a try see if it could work out the way you want.
Greolt
Post by Greolt »
Thank you Marco.
Greolt
Telrad
Post by Telrad »
The soft limits really are annoying on the z axis when you have a deep motorized table. Mine is 10+ inches. If you use the reset on the z table height, the table does not return to the previous height! You have to then find the correct laser height again. That's a big pain. If you don't reset the z table then you can only move the table up but not any lower than the starting height. To fix that you have to fish through the menus to reset the z. Pain in the butt!! I know I could set the z table to use the u axis but that solution is non-standard and with multiple people using the machine it can lead to problems.
Having the ability to turn off the soft limits on the z would be extremely helpful.
Greolt wrote:Can Mr Lee include an option to disable Z axis soft limits while he is at it? PLEASE.
Greolt
Just received a new OS update with the capability to disable the softw limit switch for the Z. But I'm not sure if it work the way you're expecting. Li said that if you disable the soft limit for Z, then you need to add a hardware limit switch instead. I'm not sure what is that as I never use Z table.
I let you try it. What is your current OS version? I'll send you a file to upgrade it and you can try it
Greolt
Post by Greolt »
Tech_Marco wrote:
Greolt wrote: I let you try it. What is your current OS version? I'll send you a file to upgrade it and you can try it
Great news Marco.
I will do that as soon as I can. Not at home till Sunday.
Greolt
Greolt
Post by Greolt »
Main Board 8.12.09.21
LCD Board 5.12.02.29
LaserCAD V6.27
Greolt wrote:Main Board 8.12.09.21
LaserCAD V6.27
Just sent you v6.46 and the new OS130310
Let me know if it works the way you want?
If so, can you take a video and post it here to share
Greolt
Post by Greolt »
Ok I have just received the info email.
I will test and report later today.
Greolt
Greolt
Post by Greolt »
Thanks for the test firmware.
I have tested the firmware and started a new thread to keep it all together.
viewtopic.php?f=8&t=1536
Greolt
