Just received a new shipment with 5x rotary included. Looks solid and quality made.
System comes with two set blades for inner and outward clamp. The max length it can support is 10" (250mm)
We put in a 57HS22 high torque motor so the word 'weakness' should be eliminated from the problem list.
High precision rotary
- Rotary500.jpg (38.74 KiB) Viewed 26484 times
