Hello Marco,
I purchased a 24 volt, 5 amp dc power supply back in November, I only used it a few times, it now stopped working. I know it is now past the 6 month warranty.
Do you happen to have the schematic or service manual for this model. I would like to attempt to repair this model.
Joe
24 volt 5 amp power supply
jpitz31
Re: 24 volt 5 amp power supply
Sorry I don't. Check if any fuse inside of the power supply. If you can identify the problem, I may be able to get parts for you from the supplier
jpitz31
Thanks Marco,
I checked the fuse and it is fine. I will attempt to troubleshoot the uint. I will let you know if I need any parts.
Joe
Joe
