I just finished the design of a power table for the K40 (also name D40K) laser machine. The finished product will be available in about 2 weeks. It will look much better than the video showing as the most parts will be sent to a factory for anodization process. The base, and the frame will be dyed in either Blue or Green color. The table comes with a 42 series stepping motor. Controller and the driver is not included but available from our shop. Price is $115 and in DIY bundle. It should take 45~50min to set it up. It can rasie 5lb object and the traveling distance is about 6.5cm (2.5"). Not much but should be handy enough to handle most task with this little K40 machine.
http://www.youtube.com/watch?v=LL5XUB8lDuQ
Mini power table for K40 Co2 laser machine
Re: Mini power table for K40 Co2 laser machine
Update: Aluminum anodization process completed. Looks much better. The bed has been upgraded from 0.6mm to 0.8mm and plated with Zinc. So, it's harder and more shiny. Plus, air holes size & density has changed from 5mm to 2mm. Better for epoxy glass cutting.
Update: 4 units just arrived. 50x unit will be coming in about 7~10 days
http://www.lightobject.com/Power-table- ... -P722.aspx
