Lasercad runtime error
twosoc
Post by twosoc »
Hi, I've been playing around for a few days since I got my setup working. I've been creating files on my new win 7 desktop pc using corel draw 12, then transefering them via flash drive to my xp laptop that I use to run the laser (its in a workshop 20meters away so the network doesn't reach).
I've just come to load an updated design and try it out, but whenever I try to import the file it crashes with a C++ runtime error. It doesn't do it for all files, just this new one and one that I made on sunday but didn't get chance to try out.
Any ideas? I've tried to reinstall lasercad but to no avail.
cheer,s tim.
Things
Re: Lasercad runtime error
Post by Things »
Sounds like the file got corrupted somewhere along the line. I'd try re-generating it and putting it on the flash drive again.
twosoc
Post by twosoc »
I managed to export it as a plt file and that worked. It doesn't seem to like big dxf files anymore. I have the original corel file somewhere I'll try doing it as a dxf again.
Things
Post by Things »
When I find a file format that works well, I usually write it down and put it on/near the computer somewhere. DXF, like many file formats, has many different versions. There is a good chance LaserCAD will only support select ones.
twosoc
Post by twosoc »
all I can think of is that the file got corrupt a little, I managed to find a slightly earlier version, (thank god for obsessive saving)and brought it up to date then exported it asa new named dxf file and it workeda treat. now though I export them all, run a test then save it as the lasercad preferred file onto the laptop, so there's not transfer, then if I update the file I save it as a different file name. Hopefully this will avoid stuff like this in future.
