Two size Pro X-Y stages arrived.
1) 5x 400mmx 600mm
2) 5x 900mm x1200mm
Each set is semi-assembly. The compete set came with 5 pieces parts and most small parts like wheels, guide, motor,... are per-installed. Buyer need to put the frames up with screws using a hex key (all comes with the package). It's very straight forwarded and it took about 45 min to assembly it.
Each stages comes with X and Y motor (57 series 2.8A and 4A) and physical limit switches installed. The set is designed to be compatible with the Pro laser head and mirror mount that we're carrying.
X-Y Stages arrived
