Hello all,
I just upgraded to the latest firmware release for the controller.(120401v7)
During cutting, the laser does not come on at all. It works normally during engraving mode.
I tried with PPI on and off.
My card uses V7 firmware.
Has anyone else seen this result?
Test file was a rectangle drawn in lasercad V5.93
I tested a cut file(simple box) still on the controller from before upgrade and it works normally. This existing file was created with Lasercad 5.85
and loaded when the controller had original firmware.
Any suggestions on which settings to change/check?
Frank
No laser output during cutting only with 120401v7 upgrade
toymanf
Re: No laser output during cutting only with 120401v7 upgrad
Hello:
I just installed both new OS and the LCv5.93. Everything worksfine. FYI, after the upgrade, you need to double check all setting on System parameters as it wiill reset to default. I'm using K40 so I have to put it back the pulse distance to 12.688 and 12.685. The area working area I also need to reset it to 280mm x 200mm
Forgot to mention, check the power on each layers as mine being reset both of speed & power to "0".
Everything seems working great after the upgrade with parameters re-entered.
Programer Li
1.图层å‚数ä¸ÂÂçš„ Powerå’ŒCorner power ä»»æ„ÂÂ一个设置为0,工作ä¸ÂÂå°†ä¸ÂÂ会出光。
2.LaserCAD5.93打开å‰ÂÂé¢版本ä¿ÂÂå˜的*.pwj5文件æâ€â€Ã‚¶Ã¯Â¼Å’图层信æÂ¯将会丢失,必须é‡ÂÂ新设置图层å‚数 (I'm sorry!)。
toymanf
Thank you Programmer Li for your input.
Marco, Could you please enligten me as to what he shared with us
Frank
Frank
Things
From what I can make out from the translation, he says:
1. Power and Corner power can not be set to 0 or it won't light.
2. Files saved in previous laserCAD versions lose all their layer parameters, so you'll need to change them back again.
Dan
Dan
