solar panel and tank
btbaxter
Postby btbaxter » Wed Mar 07, 2012 7:31 pm
setting up drain back solar system in garage and need advice on temp sensor to put in collector to activate pump in a specific temp range
Re: solar panel and tank
Postby baccus61 » Fri May 25, 2012 5:13 am
Hi,
What sort of temperature range are you looking at?
I set up a solar hot air system last year and used a 42 deg C snap disc for the cut in temp. I originally used a 32 deg one but it seemed a bit too cold when the fan kicked in so I set the temp higher so the air would be warmer when it cuts in.
I used it in the front of my home but the ceilings are 13 feet high and I have a few cracks under the doors so all the air I blow in just escapes anyway. it would be great for a small room like a bathroom or small lounge room.
Andersan
Postby Andersan » Tue Oct 28, 2014 10:57 pm
______________________
Sign up with Pass4sure.co.uk - 640-722 free dumps for getting incredible online wikipedia courses exam and Princeton University We also provide best EMC and selftestengine with guaranteed HITACHI
jasonmcGough
Postby jasonmcGough » Tue Dec 02, 2014 8:10 am
Solar panel installation is actually a eco-friendly option. This a choice that you do not want to take softly since it is a relatively large in advance expenditure. You need to know that solar technology happens to be cost-effective for your personal daily life. Discover more about the financial aspect of solar power on this page.
The quantity of power it is possible to develop employing solar power considerably differs depending on how a lot of panels you might have, in addition to their performance. A consultant can assist you figure out the amount potential you need and also what individual panels are best designed for your preferences. Should they be of high quality, you might be able to pull off getting fewer individual Gem Energy panels.
Picture-voltaic solar panels are available in two kinds. Mono-crystalline individual panels are optimal, although poly-crystalline sections are definitely the less costly choice, if you want productivity. Will not think twice to invest in high-priced solar energy panels to create a competent solar technology system.
Return to “Electronics products”
Users browsing this forum: Bing [Bot] and 0 guests
