The meter is ideal to check the output from a DC sources like a wind turbin, battery or a solar panel. With this meter you can find out how much current output the sources capable to output and it can do AmpHr logging.
For example, It's good to tell whether a 12V car battery is healthy or whether is it just an 'fake' 12V box. FYI, a 12V battery with 12.5V reading from a DVM meter doesn't mean that it's a good till it can dischage enought current. Without discharging test, you can't how good of a battery.
JLD404-AH AmpH DC amp hour meter.
- JLD404AH-Eng.pdf
- (394.31 KiB) Downloaded 2050 times
