Hi all
maybe some one can help me out because marco dont wana do anythings anymore for me.
I have the new DSP from lightobject in my 40w laser engnraver completly converted with new mea 17 stepper motor stepper driver 2M5042 laser PWm.
I use a new laptop and hade installed the lasercut 5.83 it worked perfect then I uninstalled the 5.83 and installed the 5.84 version what started out very good but after about 50 hours there started trouble first I could not open files saved prior from laser cut to my hard drive , then I get a opening screen in chinese , now the positioning in laser cut is not what the dsp GIVES TO THE LASER. it does not matter where I set the grafic in the program it does not change the location in the machine out put.
I have completly deleted the lasercut programm on the computer and new installed even try and installed the lasercut v 5.83 again.
I also have unpluged all connection on the DSP card and LCD also unpluged the main power for hours no change .
now the question if somebody here has a idea to help me out.
I can not get any support from marco anymore because he believes he had done enough I dont know what service this is but I have to live with it.
thanks and greetings
the trouble goes on with the lasercut programm and the DSP
ltran2000
Re: the trouble goes on with the lasercut programm and the D
re-install window and install 5.83 again.
