I choose to install LaserCAD on my Window 8.1 PC with CorelDraw X7 installed and no matter what I try it says "Can't find Coreldraw"
Can someone tell me what I'm missing or doing wrong ?
LaserCAD Can't find Coreldraw
SScnc
Greolt
Re: LaserCAD Can't find Coreldraw
What I would try, is to place the LaserCad installer in the CorelDraw program directory and run it from there.
SScnc
Greolt wrote:What I would try, is to place the LaserCad installer in the CorelDraw program directory and run it from there.
That is exactly what I did, no good, same thing. I even rebooted.
SScnc
Well, I can't get it to work. LaserCAD still says "can't find Coreldraw"
I can and have easily installed LaserCAD, just not the selection for Corel.
Is it possible to manually add the macro to Corel Draw ?
no the macro for CorelDraw comes with the installation.
you need to install again and select lasercad for CorelDraw and you also need the 64bit usb driver installed.
SScnc wrote:Well, I can't get it to work. LaserCAD still says "can't find Coreldraw"
Current LaserCad macro support up to X6 only
SScnc
Hi Walt, I did do the "for Coreldraw" install and the 64 driver. However, I installed the LaserCAD only version first (forgot to select the corel dropdown) then I think I got it uninstalled. Then reinstalled using the for coreldraw choice and that's when it says "Can't find Coreldraw".waltfl wrote:no the macro for CorelDraw comes with the installation.
OK, so what format is best to save designs done in CorelDraw to import into LaserCAD ?Tech_Marco wrote:Current LaserCad macro support up to X6 only
DXF ?
Steve
