new software
lanoph
new software
Post by lanoph »
Hello,
I use the RLaserCut2 with Corel Draw. I saw a better version of the same software (downloadlink), but it is only working with the mainboard, when it was from Shenhui. Does anyone Know, how and what to change that this will work with the mainboard from lightobject.com??
There is also a softwarepart included for calculation the motor-way for turning-parts and some more good features. Also it can read the compleet workingtime from the Laser and so on.
Thanks for ideas.
CL
here is the link for the softwyare. I could not upload it, becaus it is 10 MB.
http://hotfile.com/dl/74831665/1e49408/ ... 3.rar.html
Software for engraving and cutting with the laser. working only at shenhui-laser-mainboards.
maralb
Re: new software
Post by maralb »
I am trying, all ok works.
need of the password in order to modify the parameters
someone and in possession?
thanks
lanoph
Re: new software
Post by lanoph »
Hello,
which Password is used? I maybee can figure the GSM.Data-File-password from corel, if this will help.
Greetings.
CL
maralb
Re: new software
Post by maralb »
when use RLasercut3.10 asks a password in order to insert the parameters machine
to be a new code
those known not to work
lanoph
Re: new software
Post by lanoph »
Hi,
how did you start RLaserCut3. is this the software I posted here? or is it possible to get the software??
I could not get run the software I posed, because it says all the time: machine not connected and when i connected it, it will not recognice, that it is connected.
Thanks.
CL
Maybe I can figure the password out, when i can get run the software!
maralb
Re: new software
Post by maralb »
to have entirety macros installed Rlasercut2 and Rlasercut3
to try
sorry
to excuse to my English, use the translator
maralb
Re: new software
Post by maralb »
new page "Info System" of the software Rlasercut 3.10
possible to read to all the data of the time machine
Re: new software
Hi folks:
I'm in China now!!
I talked to my friend about the new DSP software. He said that our card doesn't support the "RLaserCut" as it support ShengHui's machine only. But there machine is ..... highly not recommended as I been there 3 times and show them how to imporve the quality. But unbelieable that they never take my advise and always give you "suprise" how machine build.
Anyway, the good news is that they have a very similiar software (new version) that support the laser head co-ordinate function. However, the bad news is that the new software only works for the laest model DSP card that I'm going to switch to. Sadly to say that that software is not backward comptitble though. :cry:
See attached manual and images of the new card and manuals.
lanoph
New DSP and Manual
Post by lanoph »
Hi.
attached is the picture from the new software and also the manual from the new DSP Marco wants to offer soon.
Greetings
PHCADmanual .doc
Manual from the new DSP
(3.3 MiB) Downloaded 469 times
Pic from the new DSP
