Open Protect in 130922v7 reversed!
Gadroc
In 130622 and before open protect worked by shorting to ground when the door is opened, but 130922 expects short to ground when the door is closed. Is there a way to change this behavior via configuration? This is really annoying to have to rewire your machine for a change in firmware version.
Re: Open Protect in 130922v7 reversed!
I didn't know that they have changed the 'logic' of the door protection. Let me discuss it with the programmer see if either revesed it or have a check box for changing logic level. It will take a couple days though as new year is coming and Sat/Sun
Gadroc
Not a huge rush as I have to stay on 130622 until the engraving issue is figured out anyways.
See my PM for a new OS
