Coral x6 VB plugin - need help
Rad Racer
I can't seem to get coral x6 to work with v6.81, unable to find the necessary files. Can someone offer some advise?
thanks,
Wayne
thanks,
Wayne
Re: Coral x6 VB plugin - need help
After installation the LaserCad v6.81, with the "Welcome to use" box showing up, use the drop down manual to select "CorelDraw_LaserCut" and it should install the macros for CorelDraw.
I don't have CorelDraw X6 to test but X5.
Let me know if it works out
wctx1977
I tried tho install coreldraw-lasercut x6 plugin also several times and it always gave me the message "unable to find coreldraw x6" or something like that. I gave up trying to get it to work as I was getting very frustrated and angry. Did anyone got it working successfully?
After the "plugin" installed, you need to add the macros manually from the CorelDraw Tools menu bar. See DSP card manual, page 57
Rad Racer
Good new: Using the welcome box selection I was able to load the proper files into Coral x6 and run the required macro/plugin.
Bad news: When I press the run button icon with a blank or new page it starts LaserCad just like my x3 version of Coral.....but if any artwork, even a simple circle, is on the Coral draw screen I get the following error when the run button icon is pressed.
My CoralDraw x3 version continues to function just fine.
Wayne
Wayne
JAV-1
Plug-in works with x5.
Wayne:
Use V6.77 instead as only V6.81 came with X6 plug in. Beside that, there is no difference
I'll contact the programmer to check if there is any bug. If so, I'll ask him to fix it
Rad Racer
Ok, will do. Please send me the link for v6.77.
Thanks for the help.
Wayne
Wayne
Hey Wayne, please check your email. Link just sent
Improbable Construct
I am also trying to get this to work.
I don't get any kind of welcome screen.
I have tried selecting and unselecting the "Always show welcome screen at launch" button with no success.
I have LaserCAD V6.71 and corelDRAW X4.
What am I doing wrong?
Also I have tried uninstalling and reinstalling LaserCAD as well.
Rad Racer
Yes, I got your email thanks. Haven't tried it yet, been out of town for the holiday.
Improbable,
You make the plug-in selection at the LaserCad installation welcome screen. Just run the LaserCad installation again....then select CorelDraw from the drop down menu.
Wayne
Improbable,
Wayne
Wayne, thank you for answering for me
